Domain change and hyperlinks
I am using the ‘try discourse’ domain, and I have a bunch of hyperlinks setup within my topics. If I change the domain, will these hyperlinks still work?
if you rebake it should as I understand…
./launcher enter app
rake posts:rebake
You should follow the guide below.
Hang on… if you’re on trydiscourse then you’re using our hosting, right?
If that’s the case, email team@discourse.org – you don’t need to rebake or follow the guide above.
