Draft not going away when I completed it on another device
(Blake Erickson) #1
I started a topic on my computer, but finished it on my iPhone. Now that I’m back to using my computer the draft won’t go away. I can click on several other topics, but the draft won’t go away until I refresh the page. I feel like it should go away automatically.
I was able to duplicate this on try.discourse.org
(Dave McClure) #2
This I can reproduce :slight_smile:
(Sam Saffron) #3
This is tricky to fix, we would need to message the user to junk the draft, it can also lead to some unexpected behavior.
(Jeff Atwood) #4
You didn’t close the browser on your computer at any time during this process? I assume that is what you mean, so the post was completed on another live device while both editors are open?
(Dave McClure) #5
Yes, that’s correct, @codinghorror.
I don’t think this is a severe issue @sam.
(Blake Erickson) #6
I did not close the browser but I put my laptop to sleep… (Doing this again now) and finishing on my phone.
(Blake Erickson) #7
Now I’m back on my laptop. When the laptop woke up from sleep it still said 4/4 posts. So without refreshing I just went to the main meta page, which then showed this topic had been updated, and then I went back into this topic. The whole time with the previous reply window open on the bottom of my screen. I deleted all the text in the reply window to write this reply
(Dave McClure) #8
FWIW, I think Gmail has the same issue…
(Sam Saffron) #9
I don’t think there is a correct way to fix this
(Jeff Atwood) #10
