Drop-down-visible class persists even when drop down is not visible anymore
Discourse adds the class drop-down-visible to the <body> element when a drop-down is visible.
Screenshots here on meta:
No drop down:
drop down visible (hamburger menu):
This is a very handy class, but isn’t it supposed to be removed when the drop-down is no longer visible?
Here’s a screenshot after closing the hamburger menu above:
Note that the class drop-down-visible is still present.
The same happens with the notification drop-down and the search drop-down.
That does seem odd @eviltrout we must not need this class?
This class could probably use a better name. drop-down-visible indicates whether the header will use a dropdown vs the docked format of the navigation (generally with a smaller browser width.) It is currently being used.
I suggest we rename it, then?
Should do it.
