Dropping user privileges when running docker
Hi, I’m using the docker setup. However I can’t make it work with a non-root user.
If I try to ./launcher rebuild app as non-root I get:
WARNING: Error loading config file: /root/.docker/config.json: stat /root/.docker/config.json: permission denied
Running as root, I get a working setup but obviously I don’t want to run something facing the internet as root.
How to fix this issue cleanly?
What is your setup? We don’t reference config.json anywhere explicitly in discourse_docker, so presumably that’s coming from something you’ve done.
To address your larger question, that ./launcher is run as root does not imply that Discourse itself runs as root.
so you confirm running the builder/launcher as root is safe?
I never confirm anything is safe. Caveat Executor at all times.
How do you recommend to run the docker then? I’m used to dockers that let you set an PUID and PGID…or am I the only person having issues running the builder as non-root user?
