Duplicate entries on group_users
#1
Hi,
Not sure if this is a bug or a feature, but trying to add a user to a group twice using the API calls throws an exception
Is it possible to add a “ON DUPLICATE UPDATE” and just update the ‘updated_at’ column?
Thanks
(Jeff Atwood) #2
What is the actual exception?
(Rafael dos Santos Silva) #3
Won’t this add table bloat for no benefit?
Can’t you, check group membership before trying to add the user?
#4
either ignore the re addition, or update the updated_at time
(Sam Saffron) #5
hmmm… we are already doing this:
And also offer this:
So I am confused at why you would need this for normal use (which is SSO needing this kind of fancy behavior)
This is definitely a “feature req” for
@tgxworld how do you feel about this, should it be handled transparently or return an error?
#6
oh, but this is SSO, i’m talking about adding a user to group by using the API
so, if you try to call the API to add a certain user to the same group twice, you would get this error
