Edit window not docked in my browser
(Tobias Eigen) #1
Weird new behavior exhibited on my forum - I have not been able to replicate it! Check out the animated gif below. Basically what happened is I started a reply, then when I scrollled down and back up again the edit window disappeared. It was not “docked” in my browser as it usually is. Not sure I’m using the right words to describe this problem, though found it disconcerting enough that I wanted to report it! :smile:
(Jeff Atwood) #2
Have not seen that before. Needs repro steps to be classified as bug.
(Tobias Eigen) #3
gotcha. will keep an eye out for it.
(cpradio) #4
Did you do any CSS customizations recently?
(Tobias Eigen) #5
Nope. My site had no customizations.
