Editing robot txt file
(Rahul Dhingra) #1
Continuing the discussion from Excluding user profiles in robots.txt (or allow edit of file):
I need to disallow google to index images and some content on my forum.Is it possible to edit robot.txt through backend or through terminal (putty) ?
(Uwe Keim) #3
Any update on this?
I want to exclude the Internet Archive crawler which would require something like
User-agent: ia_archiver
Disallow: /
to be added to the robots.txt file.
Any official supported way to modify the robots.txt file?
(Sam Saffron) #4
no official supported way of doing that, a PR to add support for something like this would be fine.
(Panteen Pro-V) #5
If i want to stop web crawler, how can I do this manually given that feature is not yet implemented?
(Sam Saffron) #6
Set allow index in robots txt to false in site settings.
(Panteen Pro-V) #7
You meant like this?
I’ve never have that option ticked and I still can see that the site have been crawled since.
(Sam Saffron) #8
what happens when you go to http://your-site-name/robots.txt?
(Panteen Pro-V) #9
This what I get
# See http://www.robotstxt.org/wc/norobots.html for documentation on how to use the robots.txt file
User-Agent: *
Disallow: /
and this is the stats:
Last 7 days and 30 days, there are increasing in web crawlers.
(Sam Saffron) #10
so whoever is crawling you, they are ignoring your robots.txt
(Panteen Pro-V) #11
Any advices or solution to stop the crawling completely?
(Matt Palmer) #12
Are you after something Discourse-specific, or general advice on blocking unwanted visitors?
(Panteen Pro-V) #13
Anything including inside Discourse and outside of discourse, what I want is to stop my forum from being crawled by bots, etc… (ultimately i want to see the stats Web Crawlers part remain at 0 all the time)
(Sam Saffron) #14
Well, you can change it so your forum requires users to be logged in if you insist.
(Panteen Pro-V) #15
my forum has been used only internally inside my company and it requires user to login up front.
(Sam Saffron) #16
so… no drama, nothing can be crawled
(system) #17
(Sam Saffron) #18
(Jeff Atwood) #19
Before you close this @sam did we ever add a way to amend robots.txt?
(Sam Saffron) #20
Yes but requires a plugin for now
