I just noticed a little thing that I can’t really reliably reproduce. We’re on a docker install (pretty much default) with Cloudflare (using the Cloudflare template). Not sure but maybe Cloudflare has to do with that.
Here’s what a user noticed and told me: After editing his own post he doesn’t see the edit after saving but sees it after reloading. We made sure his Browser isn’t an issue (private window, different browser, no addons, yada yada yada) but couldn’t get it fix. I tested it for me and everything worked as expected: I did instantly see my edits.
Now today I edited one of my posts in a longer thread (only a few posts long though but not an empty test thread) and saw the same “issue”. While it’s not really an issue I still think it’s not how it’s supposed to work. Just removed a few words of my post, saved and didn’t see any changes. After a browser refresh everything was there.
Any idea what might be going on? Any hints on how to hunt that thing down?
No the orange cloud means Cloudflare is proxying the connection:
If you have any of their performance features turned on for your Discourse installation it will definitely introduce delays on updates.
You need to create a page rule matching the Discourse domain turning ‘Performance Off’. You can use a page rule to cache the contents of your uploads folder to offload file transfer, but that’s about all you can use it for beyond obscuring your IP address.
I have confirmed everything works with cloudflare taken out of the game but disabling performance didn’t help on first try. I will continue the hunt to find the issue.
