Hello, I set up the email configuration but it isn’t working. I get a general “Connection reset by peer” message, and I’m not able to go on.
This is the output of my discourse-doctor:
root@vmi433455:/var/discourse# ./discourse-doctor
DISCOURSE DOCTOR Sun 29 Nov 2020 09:31:32 AM CET
OS: Linux vmi433455.server.net 5.4.0-42-generic #46-Ubuntu SMP Fri Jul 10 00:24:02 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=talk.mysite.it
SMTP_ADDRESS=mail.privateemail.com
DEVELOPER_EMAILS=noreply@mysite.it
SMTP_PASSWORD=myp4ssw0rd
SMTP_PORT=465
SMTP_USER_NAME=noreply@mysite.it
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 19.03.13, build 4484c46d9d
DOCKER PROCESSES (docker ps -a)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
068c7ce44316 local_discourse/app "/sbin/boot" 16 hours ago Up 16 hours 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp app
Discourse container app is running
==================== PLUGINS ====================
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/master/lib/plugin/metadata.rb fo r the official list.
Discourse 2.6.0.beta6
Discourse version at talk.mysite.it: Discourse 2.6.0.beta6
Discourse version at localhost: Discourse 2.6.0.beta6
==================== MEMORY INFORMATION ====================
RAM (MB): 8348
total used free shared buff/cache available
Mem: 7961 2163 4995 206 802 5379
Swap: 2047 0 2047
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 195G 18G 168G 10% /
---------- Container Disk Space ----------
overlay 195G 18G 168G 10% /
/dev/sda2 195G 18G 168G 10% /shared
/dev/sda2 195G 18G 168G 10% /var/log
==================== DISK INFORMATION ====================
Disk /dev/loop0: 30.96 MiB, 32440320 bytes, 63360 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 60.10 MiB, 63942656 bytes, 124888 sectors
Disk /dev/loop2: 30.95 MiB, 32432128 bytes, 63344 sectors
Disk /dev/loop3: 52.39 MiB, 54927360 bytes, 107280 sectors
Disk /dev/loop5: 47.5 MiB, 49799168 bytes, 97264 sectors
Disk /dev/sda: 200 GiB, 214748364800 bytes, 419430400 sectors
Disk model: QEMU HARDDISK
Disklabel type: dos
Disk identifier: 0x8d027ea0
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 1953791 1951744 953M 83 Linux
/dev/sda2 1953792 419428351 417474560 199.1G 83 Linux
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [noreply@mysite.it]: myaddress@gmail.com
Sending mail to myaddress@gmail.com. . .
Testing sending to myaddress7@gmail.com using mail.privateemail.com:465.
======================================== ERROR ========================================
UNEXPECTED ERROR
====================================== SOLUTION =======================================
This is not a common error. No recommended solution exists!
Please report the exact error message above to https://meta.discourse.org/
(And a solution, if you find one!)
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Would you like to serve a publicly available version of this file? (Y/n)Y
The output of this program may be available at http://talk.mysite.it/NzJkN2VmNzBmZWQ48efJGI.txt
You should inspect that file carefully before sharing the URL.
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
BUT FIRST, make sure that you know the first three commands below!!!
Commands to know when viewing the file with the above command (called 'less'):
q -- quit
/error<ENTER> -- search for the word 'error'
n -- search for the next occurrence
g -- go to the beginning of the file
f -- go forward a page
b -- go back a page
G -- go to the end of the file
I obviously double checked smtp details, username and password, and tested them on my mail client.
