Email rejected per DMARC policy for discourse.do.co
I recently got discourse installed on a droplet. When I send mails through Sendgrid its received by them but doesn’t go through.
Error message on Zoho: 550 5.7.1 Email rejected per DMARC policy for discourse .do .co
Error message on gmail: Unauthenticated email from do .co is not accepted due to domain’s DMARC 5.7.1 policy. Please contact the administrator of do.co domain if this was 5.7.1 a legitimate mail. Please visit 5.7.1
​Im unable to find any material that tells me how to change the sender domain. Please help me out by pointing me in the right direction. Thanks!​
Okay you just had to change the sender Id. Silly me. If anyone gets this issue hope this helps.
Could you explain this more, what exactly did you do? Changed the sender ID of what and where?
Can anyone here aside from the OP help explain what I need to do to fix this? Still unsure
Check your admin settings. There is a sender email ID. You need to change that to an actual email ID.
OK I found it, but it wasn’t called ‘sender ID’, it was just called “notification email”, here is a screenshot of the location:
I can confirm that changing this to my domain name has now enabled emails to work - whew!
Oh yes. Right. Sorry about that.
