Emails are being sent as localhost.localdomain
(Cédric Poottaren) #1
Hello,
So this is the first time I’m trying to install discourse. When I try to complete installations by verifying my email address I notice that emails from discourse are being sent as localhost.localdomain.
Since I’ve configured postfix not to allow unknown host, discourse emails dont parse through.
Is there a way I can tell discourse to use another ‘send from address’?
Thanks for your time.
(Michael Friedrich) #2
This sounds like your HOSTNAME setting was set to localhost, or isn’t an FQDN in app.yml. How exactly did you configure those settings?
Is that a local postfix mta on the same host where Discourse is running in the container, or a remote one as mail relay?
Edit: Google pointed me here again:
(Cédric Poottaren) #3
Hello,
I’ve rechecked the app.yml file and the HOSTNAME is properly configured with a FQDN.
Yes, the server hosting Discourse is also my email server running Postfix as MTA.
I finally have my Discourse instance working by abandoning the idea of using my own mail server and switched over to mailgun instead.
Thanks for the support.
(Joshua Rosenfeld) closed #4
This topic was automatically closed after 29 hours. New replies are no longer allowed.
