Embed 3rd party website in our discourse
Hello,
I am new to discourse and not much of a developer. I wanted to add this code below but it does not appear or work. Which settings do I need to change/update in order for the code below to work?
<div id="SOIDIV_firstpriorityfinancial" data-so-page="firstpriorityfinancial" data-height="550" data-style="border: 1px solid #d8d8d8; min-width: 290px; max-width: 900px;" data-psz="00"></div>
<script type="text/javascript" src="https://cdn.oncehub.com/mergedjs/so.js"></script>
<!-- ScheduleOnce embed END -->
Hi, this is discourse meta (not discord)
Where would you like this code to be added? E.g. in the header/body/footer section?
Easiest way to add it would be to go to admin > themes & create a new theme component.
Then, in the theme component, add the code to the relevant section by clicking the edit HTML/CSS button.
Add this newly created component to All your active themes and that should do the trick.
You would also need to amend the content security policy settings, since otherwise the script execution will be blocked.
Is it possible to add it on a specific topic only?
I’m afraid it’s not.
