Embedding Discourse comments in Adobe Muse webpages
(Piotr Z Marek) #1
Hello :smiley:
It is possible? I read “Embedding Discourse in Static Sites” and I configured everything as it should be (I think so).
However this does nothing. Comment box should appear on the bottom of this page, below Disqus box.
What am I doing wrong? I preffer to use Discourse comments instead Disqus.
Thanks!
(Kane York) #2
“feed polling url” isn’t set to a full URL - add http or https:// in front.
(Mittineague) #3
As the earlier input specifies to not add the protocol (establishing that mindset) perhaps the copy for the input that requires the protocol should say so?
(Jeff Atwood) #4
We should either enforce this via settings check or make it more consistent or both @techapj
(Arpit Jalan) #5
“feed polling url” does not require http / https in URL as per this commit:
@piotrek_lisowsk are you still facing this issue?
