Embedding Slideshare & Speakerdeck
#1
Is there an easy way to embed some Slideshare slides?
Can onebox help on this?
Tks!
Pablo
(sparr) #2
You would need to write a slideshare onebox if you want that to work. I suspect that onebox would be popular.
#3
Writted! My pull request here: Oneboxer for Slideshare by PabloC · Pull Request #787 · discourse/discourse · GitHub
#4
wow this community is so fast :smile:
(Kiran Patil) #5
I applied your code to our repository and not able to see the onebox for slide share with below url.
Sorry for my english :wink:
(Neil Lalonde) #6
Hmm, yeah it don’t work. I merged it because it looked good, but something is wrong.
EDIT: Oh I see another PR with a fix. :slight_smile:
#7
Sorry, forgot to add Slideshare to a whitelist.
Fix is in master. Thanks Neil.
(Fayimora Femi-Balogun) #8
You can write one for SpeakerDeck while you are at it :smile:
#9
Good idea.
I’ve just added one in another pull request. Let’s wait the next merge.
(Fayimora Femi-Balogun) #10
Looks like the Slideshare fix has been merged but I don’t see it working yet!
(Neil Lalonde) #11
Works for me!
(Jeff Atwood) #12
As I mentioned in the PR, if a site supports opengraph, you don’t need to write a custom onebox… just enable them in the whitelist. For future reference!
(Fayimora Femi-Balogun) #13
Yeah I just added a space at the end of the link and it worked.
(Craig Oda) #14
Where is the whitelist for the onebox embedding? I can’t find it on the admin interface? Is it a text file customization?
I would like to embed Slideshare. I don’t think it is working on this forum?
(Kane York) #15
Looks like it’s working to me:
(Sam Saffron) #16
We plan to add a UI for this, but have not got to it yet.
(Craig Oda) #17
@sam, thanks for the info. So, it’s not a configuration setting in
discourse/config/site_settings.yml
this is not urgent. I was just wondering if it was working yet.
@riking , yes, it’s working for me on this forum now too. neat. At some point, I would like to get it to work on another forum.
(Sam Saffron) #18
No, this is not configurable in site settings, you could build a plugin to hook stuff up but not really worth the effort since we plan to have a UI.
(Robert) #19
Do we have an UI now?
I would propose to add a way to get an embedded working for slides.com .
Have a look here: Programming by Robert Riemann
The code to embed would be like this:
<iframe src="//slides.com/rriemann/insa-pc-01/embed" width="576" height="420" scrolling="no" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe>
Nothing special. :grin:
(Robert) #20
If we need a onebox to parse the link, I think I could contribute a pull request (my first one).
