Embedding surveys (HTML)
(Riana Patel) #1
Hello,
I’m looking to embed a survey (e.g. Typeform, Google Forms) by embedding the HTML. I’ve noticed that Discourse removes elements so that the embed of a Google Form does not actually work. Is there a workaround for this issue? Or, has anyone got any other suggestions for ways to achieve this?
Thank you!
(Jeff Atwood) #2
There is no way to embed a Google Form at this time; you can link to the form, of course.
Discourse has native polls, though it is not a form builder.
(Riana Patel) #3
Is there any other way to work around to create polls/questions in a single post? e.g. embedding Twitter polls?
(Felix Freiberger) #4
That sounds like…
…is what you’re looking for.
I like the native because they are…
  • easy to create
  • embedded within the post
  • can show who voted (if enabled)
0 voters
(Riana Patel) #5
The thing they lack though is text input areas to collect responses. Multiple choice is fine, but looking for a way to allow text input as well in a single post rather than just opening up to the comments.
(Felix Freiberger) #6
Yes, text input would require either replies or an external service.
(Sam Saffron) #7
Can you expand on why replying to the post with the poll is problematic?
(Riana Patel) #8
I think a survey is different to a discussion post. For instance, users may not want their responses to be public and there could be functionality to make such responses anonymous.
(Mittineague) #9
Anonymous posting is possible, though personally I would not leave it enabled for very long.
(Christoph) #10
Typeform can now be oneboxed (which is awesome) but I wonder if any other survey/form providers might be added?
Differently asked: what are the criteria for a service to be added? Typeform has the clear advantage that it works well even in a small iframe. But is that the only reason why it was added but not others?
(Erlend Sogge Heggen) #11
It usually comes down supporting oEmbed in the right way:
