Emoji displaying as code when mixing html and markdown
(pjv) #1
See here:
Other emojis are working fine on the same site. Looks like maybe the arrow emojis were changed recently? Could that be related?
Running version 1.9.0.beta13
(Jeff Atwood) #2
Let’s see
:arrow_upper_right: looks fine to me
(pjv) #3
excellent, it works on meta.
(pjv) #4
in case the sarcasm was too subtle, though :arrow_upper_right: works here on meta, it’s still not working for me.
anyone have any idea what i might try to fix it?
(Stephen Chung) #5
:joy:
It was too subtle.
F12 and see what image URL is showing up for the emoji?
(pjv) #6
What should F12 do and in what context?
The page’s HTML shows no image URL at all. Just text.
(Stephen Chung) #7
Find the place where the emoji icon should be and see if the image DOM node is there
(pjv) #8
Here is a test case that works / doesn’t work on meta.
H3 Heading
Some text with an emoji :slight_smile:
Is it a bug now?
The fix i just discovered is to use markdown ### instead of the <H3> html element. But still seems like a rendering bug to me.
(Stephen Chung) #9
Ah. You mean your emoji code is not being cooked into actual emoji’s.
(Joshua Rosenfeld) #10
So the raw content @pjv is using is:
<H3>H3 Heading</H3>
which produces
H3 Heading
Adding a blank line resolves the issue. Raw:
<H3>H3 Heading</H3>
which produces
H3 Heading
Markdown headers work:
### H3 Heading
H3 Heading
(Stephen Chung) #11
There are obviously strange stuff going on when the <h3> tags are used.
Without a blank line, the cooked HTML does not get wrapped in <p> tags. With a blank line, the text gets wrapped in <p>.
Which seem strange because, all text should really be wrapped in <p> tags at the topmost level.
I’ve occasionally seen cooked HTML where text is not wrapped in <p> but they don’t happen too often. Can’t seem to find the pattern that will cause it to happen.
(Jeff Atwood) #12
Don’t randomly mix html and markdown for no reason, that is a recipe for pain. Use the markdown headings.
See Markdown Reference to learn more.
Image doesn't show when using html in a topic
(Sam Saffron) #13
Yeah, I don’t consider this a bug, this is a sure path to creating a monster unmaintainable nightmare mode parser.
HTML blocks have very clear semantics in CommonMark and treating them as paragraphs just because of this is not a world of pain I want to enter.
You can mix html inline and it works just fine :astonished:
You can mix html <b>inline</b> and it works just fine :astonished:
When you define a block of HTML you only break out of it properly after an empty line.
(Stephen Chung) #14
Ah. Now that makes sense.
All the lines, including the text after, are treated as raw HTML until a blank line is encountered.
