Emojis not appearing in the published message
#1
Hi everyone, I have a little problem and i can’t figure this one out.
Thanks to @cpradio vbulletin’s emojis plugin (thanks for the recent update by the way !), I wad able to add a lot of flags and keeping them organized in the emoji box (we have updated a lot of emojis and it was a mess before this plugin).
Anyway, the plugin seems to be working just fine at first : the flags appear in the box
And in the preview !
But when I post the message, no emoji, just the code. It’s not an broken image, it’s like the emoji doesn’t exist, it’s just the code.
If someone has an idea, it’d be great, my coding skills are very limited, I can only count on existing plugins to adapt :sweat_smile:
The plugin link : GitHub - iunctis/vb_emoji: Ajout de drapeaux et autres emojis
(and for comparaison, the original plugin : GitHub - cpradio/discourse-plugin-vb-emoticons: Enable emoticons found in vBulletin in Discourse)
(Mittineague) #2
Ah, what havoc misplaced punctuation can wreak
    'haha': 'images/haha.png',
    'homerargh': 'images/homerargh.gif',
the comma indicates another key-property pair, but hold on, …
#3
Thank you for the reply, that was a stupid error on my part :sweat_smile:
I upgraded with the fix, sadly the problem still exists.
Really weird
(cpradio) #4
No, the issue is far more complicated. I’m digging into it. I think I screwed this up massively in my reorganization of the code recently.
#5
So it’s not just me, I’m glad.
I had the previous version of the plugin, before your reorganization and the problem appeared between friday and sunday. I thought it was the reason of your update.
I think it’s connected to an upgrade of Discourse.
There’s nothing urgent for me but thanks for digging into it :slight_smile:
(cpradio) #6
Okay, so you are right, it isn’t my fault. Seems something in core has changed. @eviltrout, can you take a look. I’m struggling to find the root cause but even your plugin for adding emoji is now broken…
@zogstrip, might be related to this?
https://github.com/discourse/discourse/commit/7fbf902d094caf15c54e6ca2e590828c5755ec56
(cpradio) #7
Okay, I just verified it is this specific change.
If I comment out line 193, everything functions again.
(Régis Hanol) #8
I will add a way for plugins to properly add new emojis.
(cpradio) #9
If I may make a recommendation. Right now the biggest concern with the way we do it now, is we can’t do it based on a sitesetting (or at least I haven’t been able to accomplish that).
I’d really like to be able to turn off the registration of emoji’s by my plugin if the plugin is disabled. I spent a lot of time this weekend trying various approaches with no success, so if you can think of a way that would accomplish that too, that’d be great!
(Mittineague) #10
(maybe best a new Topic?)
Hmmm, I too have thought some off trying to find a way to distinguish between “enable this plugins feature(s)” and “activate this plugin”.
Some knid of conditional in plugin.rb might work
some_sitesetting == NULL OR some_sitesetting == TRUE { do stuff }
except I don’t know how to code “don’t do the auto-magical stuff”
(Régis Hanol) #11
Just pushed this new feature :wink:
https://github.com/discourse/discourse/commit/13e96ffd3be51635614034f567a812253144d49d
And here’s a boilerplate plugin you can use to create your own :cookie:
As you can see, the API is pretty simple
  • enabled_site_setting allows you to define which site setting controls this plugin
  • the register_emoji method takes 2 parameters: name and url
You don’t even need to write a single line of JavaScript :wink:
Now in master: ES6 Modules + Text Rendering
#12
Thanks a lot @zogstrip , it’s way easier now !
(cpradio) #13
Thanks @zogstrip! A like seriously wasn’t enough for this. :smile:
(cpradio) #14
Not sure if this is related, but now I’m getting this error when trying to create a new topic on my dev machine
All plugins have been removed except for tagging, akismet, data-explorer, lazyYT, and poll
/home/discourse/discourse/lib/pretty_text.rb:196:in `block (2 levels) in markdown'
/home/discourse/discourse/lib/pretty_text.rb:195:in `each'
/home/discourse/discourse/lib/pretty_text.rb:195:in `block in markdown'
/home/discourse/discourse/lib/pretty_text.rb:393:in `block in protect'
/home/discourse/discourse/lib/pretty_text.rb:391:in `synchronize'
/home/discourse/discourse/lib/pretty_text.rb:391:in `protect'
/home/discourse/discourse/lib/pretty_text.rb:176:in `markdown'
/home/discourse/discourse/lib/pretty_text.rb:245:in `cook'
/home/discourse/discourse/app/models/post_analyzer.rb:12:in `cook'
/home/discourse/discourse/app/models/post_analyzer.rb:111:in `cooked_document'
/home/discourse/discourse/app/models/post_analyzer.rb:49:in `raw_mentions'
/home/discourse/discourse/app/models/post.rb:169:in `block (2 levels) in <class:Post>'
/home/discourse/discourse/lib/validators/post_validator.rb:54:in `max_mention_validator'
/home/discourse/discourse/lib/validators/post_validator.rb:11:in `validate'
/home/discourse/discourse/lib/post_creator.rb:115:in `valid?'
/home/discourse/discourse/lib/post_creator.rb:123:in `create'
/home/discourse/discourse/lib/new_post_manager.rb:150:in `perform_create_post'
/home/discourse/discourse/lib/new_post_manager.rb:123:in `perform'
/home/discourse/discourse/app/controllers/posts_controller.rb:121:in `create'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/abstract_controller/base.rb:198:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/rendering.rb:10:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:117:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:505:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:81:in `run_callbacks'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/rescue.rb:29:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/notifications.rb:164:in `block in instrument'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/notifications.rb:164:in `instrument'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activerecord-4.2.4/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/abstract_controller/base.rb:137:in `process'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionview-4.2.4/lib/action_view/rendering.rb:30:in `process'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiling_methods.rb:106:in `block in profile_method'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal.rb:196:in `dispatch'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_controller/metal.rb:237:in `block in action'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:76:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:76:in `dispatch'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:45:in `serve'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:30:in `each'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:30:in `serve'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:821:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:38:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/flash.rb:260:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/message_bus-1.0.16/lib/message_bus/rack/middleware.rb:60:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activerecord-4.2.4/lib/active_record/query_cache.rb:36:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activerecord-4.2.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activerecord-4.2.4/lib/active_record/migration.rb:377:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/reloader.rb:73:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/better_errors-2.1.1/lib/better_errors/middleware.rb:59:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/logster-1.0.0.3.pre/lib/logster/middleware/reporter.rb:31:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/rack/logger.rb:38:in `call_app'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/rack/logger.rb:22:in `call'
/home/discourse/discourse/config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
/home/discourse/discourse/config/initializers/silence_logger.rb:26:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/static.rb:116:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/home/discourse/discourse/lib/middleware/missing_avatars.rb:21:in `call'
/home/discourse/discourse/lib/middleware/turbo_dev.rb:33:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiler.rb:276:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/engine.rb:518:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/application.rb:165:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `public_send'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `method_missing'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/content_length.rb:15:in `call'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:86:in `block in pre_process'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:84:in `catch'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:84:in `pre_process'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:53:in `process'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/connection.rb:39:in `receive_data'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/eventmachine-1.0.8/lib/eventmachine.rb:193:in `run_machine'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/eventmachine-1.0.8/lib/eventmachine.rb:193:in `run'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/backends/base.rb:73:in `start'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/thin-1.6.4/lib/thin/server.rb:162:in `start'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/handler/thin.rb:19:in `run'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/rack-1.6.4/lib/rack/server.rb:286:in `start'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands/server.rb:80:in `start'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands/commands_tasks.rb:80:in `block in server'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands/commands_tasks.rb:75:in `tap'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands/commands_tasks.rb:75:in `server'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands/commands_tasks.rb:39:in `run_command!'
/home/discourse/.rbenv/versions/2.1.2/lib/ruby/gems/2.1.0/gems/railties-4.2.4/lib/rails/commands.rb:17:in `<top (required)>'
bin/rails:4:in `require'
bin/rails:4:in `<main>'
(Régis Hanol) #15
I was able to create posts successfully but I did not have aksimet nor data-explorer locally.
(cpradio) #16
Hmm… I’ve removed all plugins, still getting the same error after getting latest of Discourse Master… very odd.
(Régis Hanol) #17
Did you rm -rf tmp/ before restarting your server?
(cpradio) #18
Yeah, I think I may know what is happening, what is the fastest way to clear out the /admin/customize/emojis section?
All of my emoticons are appearing in that list from my no longer enabled plugin…
(Régis Hanol) #19
Delete all the files that are stored in /uploads/default/_emoji/.
(cpradio) #20
K, also, the Emoji UI hates apostrophes, can’t delete an emoji whose name contains an apostrophe (also the registerEmoji logic seems to hate them too) – this seems to be how I borked my installation.
