Empty page when both category and tag are filtered
(Pad Pors) #1
in our forum if a user go into a category and then filter the tag to a specific one, he sees empty page!
I don’t get errors in console, and when I go into safe-mode and only disable unofficial plugins, the problem is solved.
is there a way to understand which plugin has caused the error without uninstall-rebuilding the site?
Custom Layouts Plugin
(Régis Hanol) #2
Look at your browser’s JavaScript console and hopefully there will be an error related to one of your plugins.
(Rafael dos Santos Silva) #3
With more than 10+ plugins (only third party, not counting official) it’s harder, but you can try removing one by one in a dev instance.
How to increase site speed
(Pad Pors) #4
no error in the browser’s console unfortunately, + :frowning: ok, I’ll try the hard way of removing them one by one .
can anyone give me a hint which plugins may be more probable for producing such a bug (empty page)?
(Mittineague) #5
You could try running QUnit tests on the plugins. IF the problem plugin has a failed test, that could be a help in narrowing things down.
