Enable_s3_uploads not applied at Theme Import
Under Admin -> Settings -> enable s3 uploads is checked.
S3 is configured properly, new post images are uploaded to S3.
Yet if I go to Admin -> Customize -> Themes -> Import, the Uploads attached to the theme get stored in the local uploads folder (not in S3).
However, if you use Admin -> Customize -> Themes -> Uploads and choose Add to manually add new Uploads, the upload will be submitted to S3.
Installed v2.0.0.beta10 +5
Is this a hosted instance or self-installed?
