Enabling the mathjax plugin
(Mario) #1
Hi,
I would like to enable the mathjax plugin. So I checked “enable mathjax plugin” on the settings page. Do I need to do anything else (like relaunching the app). And when it is enabled how can I begin to use it in the text editor?
Thanks
(Jay Pfaffman) #2
If you see the setting, then you must have installed the plugin. You can see examples of how it works on this post.
I installed it a month or so ago and can confirm that it was working then. If you have other plugins that affect how text is displayed, they could interfere with each other.
