enter key doesn't work for new line break for more than 1 line?
(Bieber Jang) #1
I just installed and started using discourse.
I posted first topic and found out that the enter key cannot make more than 1 line break.
no matter how many times I press enter key, it ignores more than 1 line break.
How can I make it accept all the enter keys I press for new lines???
(Mittineague) #2
You can’t. If you need to separate text content, try using a horizontal rule. eg?
<hr>
and more content here.
and more etc. Or try code fencing
```text
text followed by three empty lines
more text
more text
(Bieber Jang) #3
cannot make more than 1 line break?
How the normal users supposed to know
tag or code fencing stuff?
They will just hit enter key like 2 times to make more space between paragraphs…
omg… no way to make the system recognize multiple enter keys???
(Mittineague) #4
My question is why would they need to? Uneccessary empty newlines are errmm, uneccessary.
(Bieber Jang) #5
so no other way to make it as default setting?
(Mittineague) #6
Again, why the need for this? Unless you can make a strong argument for such a setting to exist I can’t see it happening in Core code. Though if you really want it for no good reason you could write / get a plugin to do it.
EDIT
I’ve been thinking of why you may be wanting this and the only reason I can think of is you’re wanting something like:
Question, scroll, scroll, scroll, scroll, scroll, scroll, scroll, scroll, scroll, scroll, scroll, answer.
IMHO, that would be a bit inconsiderate and obnoxious.
Perhaps
question
[spoiler]answer[/spoiler]
could work for you?
question
answer
Or maybe
[details="question"]answer[/details]
question
answer
(Bieber Jang) #7
it helps a lot.
Thank you :slight_smile:
