Entering titles on mobile
(Johan Jatko) #1
When creating new topics on a mobile phone (Galaxy S3 in my case), the title bar is invisible when the keyboard is brought up.
Before selecting:
When selected:
Possible fix would be shrinking the post input when title is selected? :slight_smile:
Edit: Fixed images thanks an idea by @riking
(Craig Oda) #2
I have a similar problem with a Samsung Galaxy Note 2.
(Jeff Atwood) #3
@zogstrip will get this knocked out this week. Also, “saved” will become a glyph to “save” room at the bottom of mobile editor.
(Régis Hanol) #4
Done :star2:
https://github.com/discourse/discourse/commit/20d9cb26fcd77f11d6fa40961a68df804a1a81e1
I figured there’s enough room for the saving/saved draft status so I moved it a tiny bit to the left. Let me know how it feels.
https://github.com/discourse/discourse/commit/218384e86c80a6622979521c7a8c52fc2915a0af
(Kane York) #5
Unfortunately, this isn’t enough for me on my Nexus 4.
Landscape
Vertical
(Jeff Atwood) #6
Seems to be enough (barely) on my Nexus 5. Which has a slightly bigger screen than the N4.
Actually looking at your screenshots @riking I don’t think you are on the correct version at try. See the URL in my screenshot if you want to give it a shot there.
(Kane York) #7
Oh yep - I reloaded and it was different.
(Jeff Atwood) #8
I tweaked the layout a bit more to remove some of the extraneous padding on mobile there. I also reduced the size of the entry area and the panel margins to tighten it up.
(Jeff Atwood) #9
This topic was automatically closed after 24 hours. New replies are no longer allowed.
