ERR_CONNECTION_TIMED_OUT after plugin install + rebuild
Hi,
I just tried to install 2 plugins on my week-old Discourse site. I added the Git links to the app.yml file and did a rebuild. Now the browser can’t connect to Discourse. The only thing I can think that I did wrong was that there was a prompt to clearly disk space… I can’t remember the wording, but I did that :pensive:
I’ve tried a few rebuilds.
I’ve tried commenting out the plugins.
I’ve checked the below from Googling other answers - no luck.
app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "1024MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: XXXXXXXXXXXXXXXX
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'matt@XXXXXXXXXX.com.au'
 ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: in-v3.mailjet.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: XXXXXXXXXXXXXXXXXXXXXXXXX
  DISCOURSE_SMTP_PASSWORD: "XXXXXXXXXXXXXXXXXXXXXXXXX"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: matt@XXXXXXXX.com.au
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/angusmcleod/discourse-topic-previews.git
##          - git clone https://github.com/hnb-ku/Discourse-Tiles-image-gallery.git
##          - git clone https://github.com/hnb-ku/Discourse-Slick-image-gallery.git
run:
yamllint app.yaml
  10:1      warning  missing document start "---"  (document-start)
  15:1      warning  comment not indented like content  (comments-indentation)
  20:81     error    line too long (85 > 80 characters)  (line-length)
  24:15     warning  too few spaces before comment  (comments)
  30:81     error    line too long (86 > 80 characters)  (line-length)
  34:4      warning  missing starting space in comment  (comments)
  37:4      warning  missing starting space in comment  (comments)
  43:81     error    line too long (85 > 80 characters)  (line-length)
  44:81     error    line too long (87 > 80 characters)  (line-length)
  53:4      warning  missing starting space in comment  (comments)
  59:81     error    line too long (84 > 80 characters)  (line-length)
  66:4      warning  missing starting space in comment  (comments)
  68:81     error    line too long (90 > 80 characters)  (line-length)
  71:81     error    line too long (83 > 80 characters)  (line-length)
  73:4      warning  missing starting space in comment  (comments)
  92:81     error    line too long (81 > 80 characters)  (line-length)
  93:81     error    line too long (83 > 80 characters)  (line-length)
  94:81     error    line too long (83 > 80 characters)  (line-length)
  100:81    error    line too long (99 > 80 characters)  (line-length)
  101:81    error    line too long (90 > 80 characters)  (line-length)
  102:4     warning  missing starting space in comment  (comments)
  102:81    error    line too long (85 > 80 characters)  (line-length)
CONTAINER ID        IMAGE                 COMMAND             CREATED             STATUS              PORTS                                      NAMES
38203a1e375c        local_discourse/app   "/sbin/boot"        19 minutes ago      Up 19 minutes       0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp   app
Anybody have any idea?
Have you tried commenting out topic list previews?
