Error after update
#1
digital ocean, 2gb, 1cpu
i’ve done
cd /var/discourse/
./launcher rebuild app
and get this:
/usr/bin/docker: Error response from daemon: OCI runtime create failed: container_linux.go:348: starting container process caused "process_linux.go:402: container init caused \"invalid argument\"": unknown.
what happened and how to fix it?
(Mariano Rodriguez) #2
Try with a git pull and then rebuild the app again.
(Jeff Atwood) #3
Docker isn’t functioning on your server – you’ll need to fix that before anything else.
#4
i complete git pull and rebuild, but this is not help.
#5
i was check docker (launch other image) - he is work fine.
maybe i wil get you anything logs?
