Error meanwhile upgrade from beta 5 to beta 7
(Marco) #1
Hello to all…
I have upgraded the docker…
I then I run this:
Upgrades via the web UI are disabled until you run the latest image.
To do so log in to your server using SSH and run:
cd /var/discourse
git pull
./launcher rebuild app
But to me this procedure by error:
Where I enter the email?
(Gerhard Schlager) #2
You need to edit the configuration file of your Docker container. Usually it’s /var/discourse/containers/app.yml
(Marco) #3
EDIT:
Where I find the data to be entered?
(Felix Freiberger) #4
Exactly here: Your screenshot shows the relevant DISCOURSE_SMTP_*-settings.
But you shouldn’t need that, since you only upgraded. Did you modify the container definition after installing Discourse? Do you have multiple container definitions?
(Marco) #5
I don’t have made any changes °°
(Felix Freiberger) #6
Then I have no idea why your Discourse installation ever worked. :frowning:
(Marco) #7
I have put my email, but I still get error…
(Wes Osborn) #8
Sounds like you might want to review the basic install instructions for configuring your app.yml file: discourse/INSTALL-cloud.md at master · discourse/discourse · GitHub
Also, take a look at: Troubleshooting email on a new Discourse install
(Kane York) #10
Okay, so your comment including the UN/PW was deleted, but…
Uh, the username ends with .com.com - I don’t think that’s right.
