Error when Backup
Hi…
I’ve found a notification that my backup is failed
[2018-09-20 09:11:23] [STARTED] [2018-09-20 09:11:23] 'edufast' has started the backup! [2018-09-20 09:11:23] Marking backup as running... [2018-09-20 09:11:23] Making sure '/var/www/discourse/tmp/backups/forum-edufast-5171/2018-09-20-091123' exists... [2018-09-20 09:11:23] Making sure '/var/www/discourse/public/backups/forum-edufast-5171' exists... [2018-09-20 09:11:23] Pausing sidekiq... [2018-09-20 09:11:23] Waiting for sidekiq to finish running jobs... [2018-09-20 09:11:23] Dumping the public schema of the database... [2018-09-20 09:11:23] pg_dump: server version: 9.6.6; pg_dump version: 9.5.11 [2018-09-20 09:11:23] EXCEPTION: pg_dump failed [2018-09-20 09:11:23] /var/www/discourse/lib/backup_restore/backuper.rb:170:in `dump_public_schema' /var/www/discourse/lib/backup_restore/backuper.rb:35:in `run' /var/www/discourse/lib/backup_restore/backup_restore.rb:167:in `block in start!' /var/www/discourse/lib/backup_restore/backup_restore.rb:164:in `fork' /var/www/discourse/lib/backup_restore/backup_restore.rb:164:in `start!' /var/www/discourse/lib/backup_restore/backup_restore.rb:18:in `backup!' /var/www/discourse/app/controllers/admin/backups_controller.rb:32:in `create' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.0/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/conditional_get.rb:38:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-2.0.4/lib/rails_multisite/middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/static.rb:125:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.2/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:158:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/tempfile_reaper.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/lint.rb:49:in `_call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/lint.rb:37:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/show_exceptions.rb:23:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/common_logger.rb:33:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/chunked.rb:54:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.3/lib/rack/content_length.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<top (required)>' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli/exec.rb:75:in `load' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli/exec.rb:75:in `kernel_load' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli/exec.rb:28:in `run' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli.rb:424:in `exec' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/vendor/thor/lib/thor/command.rb:27:in `run' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/vendor/thor/lib/thor.rb:387:in `dispatch' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli.rb:27:in `dispatch' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/vendor/thor/lib/thor/base.rb:466:in `start' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/cli.rb:18:in `start' /usr/local/lib/ruby/gems/2.4.0/gems/bundler-1.16.1/exe/bundle:30:in `block in <top (required)>' /usr/local/lib/ruby/site_ruby/2.4.0/bundler/friendly_errors.rb:122:in `with_friendly_errors' /usr/local/lib/ruby/gems/2.4.0/gems/bundler-1.16.1/exe/bundle:22:in `<top (required)>' /usr/local/bin/bundle:23:in `load' /usr/local/bin/bundle:23:in `<main>' [2018-09-20 09:11:23] Notifying 'edufast' of the end of the backup...
What should I do to fix it?
thanks
Hi Ronny,
It’s likely because your Postgress version is 9.5 and should be updated to 9.6.
