Error when deleting use in approval queue
(Stephen Chung) #1
Repo:
  1. Have an item waiting for approval in approval queue
  2. Click on Delete User
  3. Confirm to really delete and block email/IP
  4. Come back with Server Error dialog
  5. The item is actually successfully removed from the queue, but it still shows in the queue list (unless refreshed). Therefore, the error is most likely on the UI side that tries to remove the item from the list.
#3
I can’t repro this on my local dev environment or try. Is this still an issue for you @schungx and are you on latest?
(Stephen Chung) #4
Yes, on latest, and it still errors.
(Stephen Chung) #5
Here is the error log that may be causing this:
/var/www/discourse/app/models/user.rb:1089:in email' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:99:inblock in attribute’ (eval):6:in _fast_attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:467:inrescue in attributes’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:454:in attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:479:in_serializable_hash’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:in serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:447:inblock in merge_association’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:444:in each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:444:inmerge_association’ /var/www/discourse/lib/freedom_patches/ams_include_without_root.rb:52:in include!' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:367:inblock in include_associations!’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:in each_key' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:ininclude_associations!’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:480:in _serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:inserializable_hash’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:345:in as_json' /var/www/discourse/app/controllers/application_controller.rb:358:inserialize_data’ /var/www/discourse/app/controllers/application_controller.rb:367:in render_serialized' /var/www/discourse/app/controllers/queued_posts_controller.rb:50:inupdate’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:inprocess_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:inblock in process_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:inprocess_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:inblock in process_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:ininstrument’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:inprocess_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:inprocess_action’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:inprocess’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:104:in block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:indispatch’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:indispatch’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:inblock in <class:Constraints>’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:inblock in serve’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:inserve’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:incall’ /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/conditional_get.rb:38:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/head.rb:12:in call' /var/www/discourse/lib/middleware/anonymous_cache.rb:200:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:232:in context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:226:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:inblock in call’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:incall_app’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:incall’ /var/www/discourse/config/initializers/100-silence_logger.rb:29:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/method_override.rb:22:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/sendfile.rb:111:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:285:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.4/lib/message_bus/rack/middleware.rb:63:incall’ /var/www/discourse/lib/middleware/request_tracker.rb:186:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:incall’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:inmethod_missing’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:68:in block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:ineach’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:inprocess_client’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:inspawn_missing_workers’ /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in start' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in<top (required)>’ /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in<main>’
(Stephen Chung) #6
Got it again today. Latest version.
Error in F12:
Internal Server Error s@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:14:28648 o@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:14:28505 i@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:14:28434 trigger@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:19:5881 _onError/&lt;@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:19:7862 invokeWithOnError@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:7:19387 flush@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:7:19832 flush@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:7:20592 end@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:7:20937 run@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:7:22006 u@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:13:2804 e/i.error@https://support.chenhsong.com/assets/application-80eac2b1700aeb5aae2c6794f2cf7c5df32fffd9ba2dd6d1c49961614bf5cbe6.js:7:6301 c@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:2:7300 fireWith@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:2:8054 r@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:3:11484 n/&lt;@https://support.chenhsong.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:3:16331
u [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:29446:6](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) o [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:29425:6](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) i [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:42938:6](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) trigger [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:57309:10](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) _onError/&lt; [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:58212:10](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) invokeWithOnError [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12554:8](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) flush [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12613:8](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) flush [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12737:8](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) end [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12807:6](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) run [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:12921:10](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) u [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:33988:11](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) e/i.error [_application-80eac2b1700aeb5aae2c6794f2cf7c5df32fffd9ba2dd6d1c49961614bf5cbe6.js:8843:8](https://support.chenhsong.com/assets/_application-80eac2b1700aeb5aae2c6794f2cf7c5df32fffd9ba2dd6d1c49961614bf5cbe6.js) c [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:3272:10](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) fireWith [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:3402:6](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) r [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:9311:4](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js) n/&lt; [_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:9552:8](https://support.chenhsong.com/assets/_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js)
The error logs got this:
NoMethodError (undefined method `email' for nil:NilClass)
/var/www/discourse/app/models/user.rb:1053:in `email'
/var/www/discourse/app/models/user.rb:1053:in `email' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:99:in `block in attribute' (eval):6:in `_fast_attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:467:in `rescue in attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:454:in `attributes' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:479:in `_serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:in `serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:447:in `block in merge_association' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:444:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:444:in `merge_association' /var/www/discourse/lib/freedom_patches/ams_include_without_root.rb:52:in `include!' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:367:in `block in include_associations!' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:in `each_key' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:366:in `include_associations!' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:480:in `_serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:361:in `serializable_hash' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/active_model_serializers-0.8.3/lib/active_model/serializer.rb:345:in `as_json' /var/www/discourse/app/controllers/application_controller.rb:368:in `serialize_data' /var/www/discourse/app/controllers/application_controller.rb:377:in `render_serialized' /var/www/discourse/app/controllers/queued_posts_controller.rb:50:in `update' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:16:in `block in &lt;class:Constraints&gt;' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:38:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:200:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:186:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start' /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `&lt;top (required)&gt;' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `&lt;main&gt;'
#7
I’m still not able to reproduce this. Do you have custom plugins installed? perhaps a plugin is acting up?
(Joffrey Jaffeux) #8
Also not able to reproduce this
