Error when embed swf file
(Khoa Nguyen) #1
I read a few posts about this topic in http://meta.discourse.com but none of them work for me.
I enabled “enable flash video onebox” in setting >> onebox
I set my domain in whitelist domain list (both hoidapyhoc.com and media.hoidapyhoc.com)
Here is an example of swf file: http://media.hoidapyhoc.com/tainguyen/cell/ER.swf
Here is the my test topic
http://ask.hoidapyhoc.com/t/testing-for-swf-embed/24/1
Onebox setting screenshot:
The browser console log show : 404 error with this URL: http://ask.hoidapyhoc.com/onebox?url=http://media.hoidapyhoc.com/tainguyen/cell/Cellstructureandfunction.swf
@sam @codinghorror
(Jeff Atwood) #2
@zogstrip can you quickly check this locally? does embedding swf/flv, if enabled, still work?
(Khoa Nguyen) #3
I changed the links above to my production website. Still not work.
@zogstrip you’re still admin of my discourse instance
(Régis Hanol) #4
sfw/flv oneboxing works just fine.
The issue comes from the domains you’ve whitelisted. They don’t support OpenGraph and generate errors.
(Khoa Nguyen) #5
@zogstrip I saw you embed flash file in try.discourse.org. How did you do that?
http://i.imgur.com/4GQWRhC.png
(Régis Hanol) #6
I just pasted the URL you gave as an example. The only difference between try and your instance is that try doesn’t have the 2 whitelisted domains you mentioned.
(Michael Solomon) #7
HI.
i dont get 404 error but it’s not embed my SWF, just show a link to download the SWF
