Error when moving posts out of a topic into a new topic
(Anton) #1
Version: v1.5.0.beta7 +58
INFO
NoMethodError (undefined method `private_message?' for nil:NilClass)
/var/www/discourse/app/models/post_alert_observer.rb:49:in `after_create_post_revision'
infobacktraceenv
Backtrace
/var/www/discourse/app/models/post_alert_observer.rb:17:in `after_create'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rails-observers-0.1.2/lib/rails/observers/active_model/observing.rb:352:in `update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rails-observers-0.1.2/lib/rails/observers/activerecord/observer.rb:118:in `block (2 levels) in define_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:432:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:228:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:228:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:506:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:506:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:506:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_create_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/callbacks.rb:306:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/timestamp.rb:57:in `_create_record'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/persistence.rb:504:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/callbacks.rb:302:in `block in create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_save_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/callbacks.rb:302:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/persistence.rb:142:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/validations.rb:43:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/attribute_methods/dirty.rb:29:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/transactions.rb:291:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/transactions.rb:351:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/database_statements.rb:211:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/transactions.rb:220:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/transactions.rb:348:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/transactions.rb:291:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/persistence.rb:51:in `create!'
/var/www/discourse/lib/post_revisor.rb:306:in `create_revision'
/var/www/discourse/lib/post_revisor.rb:301:in `create_or_update_revision'
/var/www/discourse/lib/post_revisor.rb:202:in `revise'
/var/www/discourse/lib/post_revisor.rb:194:in `revise_and_create_new_version'
/var/www/discourse/lib/post_revisor.rb:165:in `revise_post'
/var/www/discourse/lib/post_revisor.rb:115:in `block in revise!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction'
/var/www/discourse/lib/post_revisor.rb:114:in `revise!'
/var/www/discourse/app/controllers/posts_controller.rb:165:in `update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.5/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiling_methods.rb:106:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:45:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiler.rb:276:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.1.1/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:580:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:674:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:529:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
ENV
hostname	kozovod.com-app
process_id	[20732, 20722]
application_version	0613399d7abdb2c54aade2eb9c466f8f8d9d5de1
HTTP_HOST	forum.kozovod.com
REQUEST_URI	/posts/12818
REQUEST_METHOD	PUT
HTTP_USER_AGENT	Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36
HTTP_ACCEPT	application/json, text/javascript, */*; q=0.01
HTTP_REFERER	http://forum.kozovod.com/t/bolezni-beremennyh-koz/1653/2
HTTP_X_FORWARDED_FOR	103.192.193.144
HTTP_X_REAL_IP	103.192.193.144
username	meg
params	null
(Jeff Atwood) #2
I don’t care about what you posted. What are the repro steps? That is rule one of the bug category. Post repro steps.
(Anton) #3
Tried to move posts out of a topic into a new topic.
(Erlend Sogge Heggen) #4
Yes, but, we all do that from time to time without running into trouble. In order to look into the issue the developers need to know what steps to follow to break it.
(cpradio) #5
Are you trying to move posts from an actual topic to a private message? Or from a private message to another private message? Trying to figure out the relation to private messages in the error message.
(Anton) #6
If I knew the reproduction steps, I’d give the detailed info. Unfortunately, I don’t. I shared the backtrace with the hope that it can be analyzed and a possible issue can be detected.
From public post to a public post.
