Error when pressing password reset button
(kushagra) #1
i have started my own Forum ask.bloggingstandard.com but users can not reset password
(Jeff Atwood) #2
Sounds like your email setup is not working? If you go to Admin, Email, send test email do you get it?
(kushagra) #3
ya its working perfectly. i have also tested it on mail-tester.com
(Jeff Atwood) #4
So the mail is being sent but it is not arriving in users mailboxes? That points to a deliverability problem.
(kushagra) #5
i dont think so because when i tested resetting password then i putted username and clicked reset password but the option reset password not working
(kushagra) #6
(Jeff Atwood) #7
Is there anything in /logs in your browser? Try clearing logs, then pressing that button to see if any error appears in logs related to the button action.
(kushagra) #8
I have cleared all the logs ,cache and all but not working
(Jay Pfaffman) #9
I’ve seen something like this lately. Mail tests work, but mail doesn’t go out. No errors in discourse, no logs at mailgun.
If seems like a sidekiq problem. I think they sometimes, a restart will help.
(Jay Pfaffman) #10
Update: The site I was thinking about was still not sending mail (it’s been up for nearly a month and they’ve been having this problem the whole time, best I can tell). I did a ./launcher rebuild app and am hoping that this will solve whatever problem that might actually have been fixed.
Is there some easy way that a Normal Person can see that Sidekiq is working correctly? There’s no link to it anywhere, is there? That’s https://forum.example.com/sidekiq/ if you’re looking for it.
