Error while bootstrapping Discourse
#1
This is a new installation, i tried to run “sudo ./launcher bootstrap app”, but i get
WARNING: No swap limit support
(): could not find expected ‘:’ while scanning a simple key at line 49 column 3 -e LANG=en_US.UTF-8
YAML syntax error. Please check your /var/docker/containers/*.yml config files.
when i tried to check the /var/docker/containers/*.yml files, i saw that there is no /var/docker directory, but if i run sudo wget -qO- https://get.docker.io/ | sh it says its already installed. Just in case, i’m running on bitnami not Digital Ocean.
(Dave McClure) #2
If you’re on the latest and installed according to the instructions, the YAML files you need to check are probably in this directory:
/var/discourse/containers/
#3
@mcwumbly You’re right, it was /var/discourse/containers/app.yml, i ran it through a YAML checker and it said
syntax error on line 49, col 2: smtp_port = 587
I cant find what the error is though. Heres the entire file:
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting by uncommenting the web.ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  - "templates/sshd.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "80:80"   # fwd host port 80   to container port 80 (http)
  - "2222:22" # fwd host port 2222 to container port 22 (ssh)
params:
  ## Set db_shared_buffers to 1/3 of the memory you wish to allocate to postgres
  ## on 1GB install set to 128MB on a 4GB instance you may raise to 1GB
  #db_shared_buffers: "128MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  #UNICORN_WORKERS: 2
  DISCOURSE_DEVELOPER_EMAILS: 'vbsmart.dc@gmail.com'
  DISCOURSE_HOSTNAME: 'discourse.dserve-06.bitnamiapp.com'
  ## TODO: The mailserver this Discourse instance will use
  smtp_address = "smtp.sendgrid.net"
  smtp_port = 587
  smtp_domain = discourse.dserve-06.bitnamiapp.com
  smtp_user_name = '*********' #Its not like this in the file, I'm just not going to put this online obviously
  smtp_password = '**********'
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discouse
## http://discourse.example.com/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  #- exec: apt-get -y install whois # for mkpasswd
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  #- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
  ## If you want to authorized additional users, uncomment and change:
  #- exec: ssh-import-id username
  #- exec: ssh-import-id anotherusername
  - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
(Dave McClure) #4
Pretty sure you wan’t to remove the quotes around the address on this line:
#5
apparently i need a “:” somewhere in that line, but i tried every sequence
i could think of and i still got errors.
(Neil Lalonde) #6
This is not valid YAML syntax:
You need to use colons, like so:
smtp_address: smtp.sendgrid.net
(Dave McClure) #7
Also, the keys in the sample file are all caps and start with DISCOURSE_
  DISCOURSE_SMTP_ADDRESS: smtp.example.com         # (mandatory)
  #DISCOURSE_SMTP_PORT: 587                        # (optional)
  #DISCOURSE_SMTP_USER_NAME: user@example.com      # (optional)
  #DISCOURSE_SMTP_PASSWORD: pa$$word               # (optional)
#8
Thanks everyone, the build is working, hopefully it’ll end without errors
#9
The bootstrapping was successful, thanks all!
