Error while installing discourse-oauth2-basic plugin
Can u help me to install discourse-oauth2-basic plugin…it’s giving error while:
  • exec:
    cd: $home
    hook: bundle_exec
    cmd:
    - su discourse -c ‘bundle install --deployment --verbose --without test --without development’
    - su discourse -c ‘bundle exec rake db:migrate
    - su discourse -c ‘bundle exec rake assets:precompile
executing this command…
What version of Discourse are you using?
Discourse Version - v1.9.0.beta13 +136
My older discourse server is already working on this version only…
That version is from 2017, is unsupported, and has numerous security vulnerabilities. You should update to a supported version ASAP.
after update it will work…
The discourse-oauth2-basic plugin is compatible with the latest version of Discourse, yes
how to upgrade discourse…via UI its disabled…
Rebuild from the command prompt.
If you are using docker: from the discourse directory initiate:
./launcher rebuild app
If you are on a non-docker setup then following might help:
git pull
bundle install
i am on a Docker setup…with three containers…Redis, App and Data…
This Topic may be some additional help, good luck!:
