Error with linked images size
This is proving to be a bit of a problem. I’ve set the image limit as high as it can go (102400 kb or 102.4MB) yet images that are only around 5MB in size, soon after they are linked from other sites, it brings up the message in the title and you have to click through to the URL to see it. this is the case for a lot of JPEGs and GIFs especially. It doesn’t seem to be an issue with uploaded images from the one or two I’ve tested.
Please elaborate; feel free to use screenshots. I’m not quite parsing where that is happening, or if that is an error message, if it is happening hosting from Discourse vs one-boxing, etc. So, what seems to be the issue? :slight_smile:
I’m hosting on NodeChef.
What happens is the image is linked, it displays as normally for a few minutes, then after that, it changes into this.
Does the same thing happen is you post on try.discourse.org? If not it’s an issue for nodechef
