Errors when I changed my hostname
(Jared Needell) #1
So I went into app.yml to change my hostname.
Did a ./launcher bootstrap app thinking that’s what I needed to do to rebuild. Got an error so I did rebuild app instead same errors.
So I rebooted and tried again, no luck
Here’s a pastebin of my rebuild output
http://pastebin.com/4yNtdenq
Sorry if this is a repost just panicking that I didn’t lose my data.
(Jared Needell) #2
Can anyone help out with this?
Correct way to update docker?
(Sam Saffron) #3
Looks like a really old install, something is bad db wise.
PG::InvalidTextRepresentation: ERROR:  invalid input syntax for integer: ""
: UPDATE site_settings SET value = value::integer * 1440 WHERE name = 'default_email_digest_frequency' AND value IS NOT NULL/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.9.2/lib/patches/db/pg.rb:90:in `exec'
to fix:
./launcher enter app
rails c
> SiteSetting.exec_sql("DELETE site_settings WHERE name = 'default_email_digest_frequency' ")
We should probably amend the migration to be more forgiving here.
(Jared Needell) #4
So I’m only maybe a 1 month or 2 behind.
I ran what you tried then did a rebuild app again. Still failed, here’s a paste bin.
http://pastebin.com/RLi7KBPZ
Do you think this has anything to do with the fact I did a “bootstrap” app instead of a “rebuild” app when I updated the app.yml file to an existing discourse?
(Jared Needell) #5
Looks like the email digest error never went away
(Sam Saffron) #6
Try changing that site setting then via admin interface
(Jared Needell) #7
Made that change via admin console and worked thanks!
