Exception on Jobs::PollFeed
(Justin Bowes) #1
I’m trying to bring an RSS feed from another site into my brand new Discourse Docker installation (love this feature btw!). Setup seems straightforward, but not seeing any result, I manually kicked off the Jobs::PollFeed task in Sidekiq. Here’s what I see in production.log after I do that:
Started POST "/sidekiq/scheduler/Jobs::PollFeed/trigger" for xxx.xxx.xxx.xxx at 2014-06-11 18:07:05 +0000
exception: incompatible character encodings: UTF-8 and ASCII-8BIT
context: {:current_db=>"default", :current_hostname=>"discourse.informilabs.com"}
backtrace: /var/www/discourse/app/models/search_observer.rb:28:in `update_posts_index'
/var/www/discourse/app/models/search_observer.rb:46:in `after_save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rails-observers-0.1.2/lib/rails/observers/active_model/observing.rb:352:in `update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rails-observers-0.1.2/lib/rails/observers/activerecord/observer.rb:118:in `block (2 levels) in define_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:424:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:221:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:221:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:215:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:215:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:86:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.1/lib/active_support/callbacks.rb:86:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/callbacks.rb:302:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/persistence.rb:103:in `save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/validations.rb:51:in `save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/attribute_methods/dirty.rb:21:in `save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:268:in `block (2 levels) in save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:329:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/connection_adapters/abstract/database_statements.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:208:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:326:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:268:in `block in save'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:283:in `rollback_active_record_state!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/transactions.rb:267:in `save'
/var/www/discourse/lib/post_creator.rb:225:in `save_post'
/var/www/discourse/lib/post_creator.rb:61:in `block in create'
/var/www/discourse/lib/post_creator.rb:57:in `create'
/var/www/discourse/app/models/topic_embed.rb:40:in `block in import'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/connection_adapters/abstract/database_statements.rb:211:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/connection_adapters/abstract/database_statements.rb:219:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.1/lib/active_record/connection_adapters/abstract/database_statements.rb:211:in `transaction'
/var/www/discourse/app/models/topic_embed.rb:33:in `import'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:38:in `block in poll_feed'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:32:in `each'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:32:in `poll_feed'
/var/www/discourse/app/jobs/scheduled/poll_feed.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:131:in `block (2 levels) in perform'
The feed itself is UTF-8 RSS, chock full of HTML entities.
My guess is that the solution is similar to what was done here, but my Rails is too rusty and the line notes on that commit too ominous for me to attempt a fix/PR.
Can I provide any more information?
(Justin Bowes) #2
Maybe I misinterpreted the error. After adding new articles to the RSS feed, Discourse is posting them as expected.
Again, great feature, thanks!
(Jeff Atwood) #3
