Extracting Discourse from External Tool
(Ranga Ta) #1
Hi
Please explain the process to extract the discourse data from API. We are trying to load the discourse data into another instance.How to extract the data using a Discourse query from External Tool using an API call
Thanks
Ranga
(Jay Pfaffman) #2
What information do you want? What application do you want to move that information to?
As your question is written, the answer is to search for the API #howto.
(Ranga Ta) #3
For Example, I want to extract the User and event information from Discourse from API? Any example will be helpful
Thanks
Ranga
(Vinoth Kannan) #4
Look at http://docs.discourse.org
You can get information of any page (almost) by adding .json to the URL. For example
https://meta.discourse.org/u/Ranga_TA.json
