Failed send job email
(jeff_l) #1
I am using 0.9.6.3
1
"---\n- !ruby/class 'Jobs::UserEmail'\n- :delayed_perform\n- - :type: :user_posted\n :user_id: 9\n :notification_id: 13\n :current_site_id: default\n"
Error Class	EOFError
"---\n- !ruby/class 'Jobs::UserEmail'\n- :delayed_perform\n- - :type: :user_posted\n :user_id: 7\n :notification_id: 14\n :current_site_id: default\n
Error Class	Net::SMTPSyntaxError
Error Message	 501 5.1.7 Bad sender address syntax
3
{"type"=>"digest", "user_id"=>3, "current_site_id"=>"default"}
(Sam Saffron) #2
I suspect the email address your forum is sending emails from has a bad format
(jeff_l) #3
Hi sam
the follow setting works well on test email, and welcome email when user register.
config.action_mailer.delivery_method = :smtp
   config.action_mailer.smtp_settings = {
     :address              => "secure.emailsrvr.com",
     :port                 => 465,
     :domain               => 'yourdomain.com',
     :user_name            => 'support@yourdomain.com',
     :password             => 'password',
     :authentication       => 'login',
   #  :enable_starttls_auto => true
     :tls                 => true }
notification_email in setting of the admin control panel.
(Sam Saffron) #4
Try renaming to
support@x-mirage.com
I don’t think that format you are using is supported.
(Sam Saffron) #5
Recategorized this as a bug, we should not allow you to save this setting with an invalid email, the setting must comply with an email valid check.
(Jeff Atwood) #6
We should also be checking for other invalid settings, like minimum post size zero, etc.
(Jeff Atwood) #7
@Neil how are we doing on validating for reasonably correct email in settings, as well as preventing zero in settings where that is utterly unsupported?
(Neil Lalonde) #8
This one got buried far down on my todo list. I’ll bump it up.
(Jeff Atwood) #9
Are we validating email-expected fields to be actual emails yet?
(Jeff Atwood) #10
This is now complete, email addresses are validated as emails.
Sending email using IP address as the domain?
(Jeff Atwood) #11
