"failed to bootstrap" with git reset error on DigitalOcean
(Sam Bauwens) #1
Hi!
I tried installing discourse on DigitalOcean on a 1GB droplet (with 2GB swap) by exactly following the official guide step by step but when I execute ./launcher bootstrap app, I get the following error:
I, [2014-08-01T12:09:08.214594 #39]  INFO -- : > cd $home && git reset --hard
fatal: Not a git repository (or any of the parent directories): .git
I, [2014-08-01T12:09:08.227842 #39]  INFO -- :
2014-08-01 12:09:08 UTC LOG:  received smart shutdown request
2014-08-01 12:09:08 UTC LOG:  autovacuum launcher shutting down
2014-08-01 12:09:08 UTC LOG:  shutting down
2014-08-01 12:09:08 UTC LOG:  database system is shut down
/pups/lib/pups/exec_command.rb:85:in `spawn': cd $home && git reset --hard failed with return #<Process::Status: pid 174 exit 128> (RuntimeError)
        from /pups/lib/pups/exec_command.rb:55:in `block in run'
        from /pups/lib/pups/exec_command.rb:53:in `each'
        from /pups/lib/pups/exec_command.rb:53:in `run'
        from /pups/lib/pups/command.rb:6:in `run'
        from /pups/lib/pups/config.rb:85:in `block (2 levels) in run_commands'
        from /pups/lib/pups/config.rb:76:in `each'
        from /pups/lib/pups/config.rb:76:in `block in run_commands'
        from /pups/lib/pups/config.rb:75:in `each'
        from /pups/lib/pups/config.rb:75:in `run_commands'
        from /pups/lib/pups/config.rb:71:in `run'
        from /pups/lib/pups/cli.rb:31:in `run'
        from /pups/bin/pups:8:in `<main>'
19b0f111c9aeb955122a0b6eeafd59b93d0169ad6e14fd49c5a1d270f301d009
FAILED TO BOOTSTRAP
Should there be a repo on the $home folder?
(Del Boy Trotter) #2
This is happening for me now - I installed yesterday and everything went fine - now today i get the same as above?
(Del Boy Trotter) #3
I, [2014-08-01T14:41:43.534683 #38]  INFO -- : > cd $home && git reset --hard
I, [2014-08-01T14:41:43.556864 #38]  INFO -- :
2014-08-01 14:41:43 UTC LOG:  received smart shutdown request
2014-08-01 14:41:43 UTC LOG:  autovacuum launcher shutting down
2014-08-01 14:41:43 UTC LOG:  shutting down
2014-08-01 14:41:45 UTC LOG:  database system is shut down
/pups/lib/pups/exec_command.rb:85:in `spawn': cd $home && git reset --hard failed with return #<Process::Status: pid 214 exit 128> (RuntimeError)
c67cfb14c6246d5db315b754ff3d6b3ee2ad946216b2dfc0d81b33bacd0ea9f6
FAILED TO BOOTSTRAP
azureuser@shangrihell:/var/docker$
(Del Boy Trotter) #4
Anyone got any ideas on this? it’s really sucking the jam out of my donut
(Del Boy Trotter) #5
I tried reverting my discourse_docker repo to 4b6456ef9e1c9f9c043e6d1a0acedcc458c247c1 but no luck… not sure where the issue resides so not sure what I need to do
(Jeff Atwood) #6
Does it still happen if you run
./launcher rebuild app
Again?
(Neil Lalonde) #7
For what it’s worth, I bootstrapped a new site on Digital Ocean this morning and didn’t have this problem.
(Marcelo Toscano) #8
Same problem here …
(Adam Capriola) #9
I am getting this error too (1 GB droplet with 2 GB swap).
(Nick Fulcher) #10
Ditto for me. New fresh install and I get this error today.
(Nick Fulcher) #11
Yes, same error if you run ./launcher rebuild app
(Neil Lalonde) #12
I just reproduced this problem too. To fix it, I uncommented the “version: tests-passed” line:
Seems like there’s something wrong if you don’t specify the version in the yml file. Using tests-passed is what I always do because I don’t want to get commits that haven’t been tested.
(Nick Fulcher) #13
This fixed the issue for me.
(Alex) #14
Worked for me too, thanks.
(Jeff Atwood) #15
Why would this suddenly be a problem @sam?
(Sam Saffron) #16
This is @supermathie’s fault
https://github.com/discourse/discourse_docker/commit/1a58daf495070de42840b00e05b860c156d836ef#diff-88f37680d05e1960495df9499f6a40dc
Also, I blame yml for being a stickler.
(Michael Brown) #17
Huh, it parsed as valid yaml. Did whatever use it not expect a blank parameters?
“Yes, we have no parameters.”
(Sam Saffron) #18
Yes, it fails, you need to put a dummy param there for your hack to work.
(Michael Brown) #19
But but but it’s valid yaml!
I guess I should have tested. /wristslap
(I thought I did actually)
(Sam Saffron) #20
Its invalid in that params is a string and not a hash like its expected to be.
You can not merge strings with hashes… Add a dummy param and Ill merge that in, everyone will be happy and the world will be full of sunshine rainbows and unicorns.
At least until I get a second non yaml config system in place.
