Failed to bootstrap
(Jay Patel) #1
HI all,
I was getting " failed to bootstrap error. so followed from other posts. it works when i disable backup to dropbox plugin with latest release 1.8.2 anyone else having same problem?
Thanks,
Jay
(Jay Pfaffman) #2
If you think it’s the Dropbox plugin, you should let @Falco know. (but I just did)
(Jay Patel) #3
Thanks Jay :slight_smile:
(Rafael dos Santos Silva) #4
I just did a rebuild on a VPS using Discourse latest and Dropbox plugin just fine.
(Jay Patel) #5
Hi, Thanks for replying. I am having problems when i turn plugin on and rebuild docker.
Should I send any logs or something?
Thanks,
Jay
(Rafael dos Santos Silva) #6
Well we need the full rebuild log (minus redacted passwords) to be able to figure out something.
(Jay Patel) #7
./launcher rebuild app > rebuild.log will do ?
(Jay Patel) #8
here is log file :
https://paste.fedoraproject.org/paste/YJ4XxRS~42Pa3MSNesJIFA
Thanks,
Jay
(Rafael dos Santos Silva) #9
Cool, please use the stable branch of the plugin if you want to use the stable branch of Discourse.
(Jay Patel) #10
Thanks.
I thought it takes stable plugin with stable branch … Where can i pass an argument to point discourse to use stable plugin?
(Rafael dos Santos Silva) #11
On the app.yml:
git clone -b stable https://github.com/xfalcox/discourse-backups-to-dropbox.git
(Jay Patel) #12
Awesome :slight_smile: you are Saviour. Thanks a lot.
