Fails to upload a file
(Franz) #1
I’m reviving this issue: Discourse Meta.
I tried to upload two files (via drag & drop to the post editor). The first file (1035 KB) uploaded fine, but the second file (3299 KB) fails to upload: the upload progress counter restarts at 0% many times and never reaches 100%.
The max upload size is set to 50 MB in the settings.
Any idea what’s going on?
(Kane York) #2
You’re going to need to tell NGINX that it should be allowing uploads of up to 50MB. You’ll need to do this with a replace command in the app.yml container definition file.
Someone else can tell you the exact command…
(Franz) #3
Thanks, something like this maybe? Riding the Clutch — Upload filesize limit and nginx
(Régis Hanol) #4
That’s the one :wink: Here’s how to do it
https://meta.discourse.org/t/upload-maximum-value/15159/5?u=zogstrip&source_topic_id=15670
(Franz) #5
Works perfectly, thanks a lot!
(Régis Hanol) #6
