Favicon 404 causes error
(Anton) #1
Version: v1.5.0.beta7 +58
Shareable link: http://forum.kozovod.com/logs/show/e5a21a989adb76905c5decd3936a657d
INFO
Invalid favicon_url http://forum.kozovod.com/uploads/default/1497/04bd7421ba896076.ico: 404 Not Found
["/usr/local/lib/ruby/2.0.0/open-uri.rb:353:in `open_http'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:709:in `buffer_open'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:210:in `block in open_loop'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:208:in `catch'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:208:in `open_loop'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:149:in `open_uri'", "/var/www/discourse/lib/freedom_patches/open_uri_redirections.rb:70:in `open_uri'", "/usr/local/lib/ruby/2.0.0/open-uri.rb:689:in `open'", "/var/www/discourse/lib/file_helper.rb:17:in `block in download'", "/var/www/discourse/lib/file_helper.rb:16:in `open'", "/var/www/discourse/lib/file_helper.rb:16:in `download'", "/var/www/discourse/app/controllers/static_controller.rb:98:in `block in favicon'", "/var/www/discourse/lib/distributed_memoizer.rb:28:in `memoize'", "/var/www/discourse/app/controllers/static_controller.rb:96:in `favicon'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/implicit_render.rb:4:in `send_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:198:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rendering.rb:10:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:20:in `block in process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:117:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:117:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:505:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:505:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:92:in `__run_callbacks__'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:81:in `run_callbacks'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/callbacks.rb:19:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rescue.rb:29:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `block in instrument'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications/instrumenter.rb:20:in `instrument'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/notifications.rb:164:in `instrument'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/instrumentation.rb:30:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/railties/controller_runtime.rb:18:in `process_action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/abstract_controller/base.rb:137:in `process'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.5/lib/action_view/rendering.rb:30:in `process'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiling_methods.rb:77:in `block in profile_method'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:196:in `dispatch'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_controller/metal.rb:237:in `block in action'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:76:in `dispatch'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:45:in `serve'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:43:in `block in serve'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `each'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/journey/router.rb:30:in `serve'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/routing/route_set.rb:817:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:25:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'", "/var/www/discourse/lib/middleware/anonymous_cache.rb:127:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/params_parser.rb:27:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/flash.rb:260:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/cookies.rb:560:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/query_cache.rb:36:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.5/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:88:in `__run_callbacks__'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.5/lib/active_support/callbacks.rb:81:in `run_callbacks'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/callbacks.rb:27:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/middleware/reporter.rb:31:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:38:in `call_app'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/rack/logger.rb:22:in `call'", "/var/www/discourse/config/initializers/100-quiet_logger.rb:10:in `call_with_quiet_assets'", "/var/www/discourse/config/initializers/100-silence_logger.rb:26:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.5/lib/action_dispatch/middleware/request_id.rb:21:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiler.rb:170:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.1.1/lib/message_bus/rack/middleware.rb:60:in `call'", "/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/engine.rb:518:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/application.rb:165:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `public_send'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.5/lib/rails/railtie.rb:194:in `method_missing'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:580:in `process_client'", "/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'", "/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:674:in `worker_loop'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:529:in `spawn_missing_workers'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:140:in `start'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/bin/unicorn:126:in `<top (required)>'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'", "/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'"]
ENV
hostname	kozovod.com-app
process_id	[20732, 20722]
application_version	0613399d7abdb2c54aade2eb9c466f8f8d9d5de1
HTTP_HOST	forum.kozovod.com
REQUEST_URI	/favicon/proxied?http%3A%2F%2Fforum.kozovod.com%2Fuploads%2Fdefault%2F1497%2F04bd7421ba896076.ico
REQUEST_METHOD	GET
HTTP_USER_AGENT	Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/47.0.2526.106 Safari/537.36
HTTP_ACCEPT	image/webp,image/*,*/*;q=0.8
HTTP_REFERER	[http://forum.kozovod.com/t/sovremennaya-tehnika-v-pomoshh-kozovodu-fermeru/1558, http://forum.kozovod.com/users/meg/notifications]
HTTP_X_FORWARDED_FOR	103.192.193.144
HTTP_X_REAL_IP	103.192.193.144
params	null
BACKTRACE
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/logger.rb:74:in `add_with_opts'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/logger.rb:35:in `add'
/usr/local/lib/ruby/2.0.0/logger.rb:445:in `warn'
/var/www/discourse/app/controllers/static_controller.rb:103:in `rescue in block in favicon'
/var/www/discourse/app/controllers/static_controller.rb:97:in `block in favicon'
(Sam Saffron) #2
If you have an invalid favicon, best thing you can do is fix the favicon url
(Anton) #3
The issue is, it has always been that and the issue had never happened until I upgraded just now to the latest commit through admin panel.
The URL is working fine and I can download the favicon file and open it in a standard viewer.
(Sam Saffron) #4
http://forum.kozovod.com/uploads/default/1497/04bd7421ba896076.ico is 404 for me.
(Anton) #5
I have it right now in a special topic where I store all such images:
Can’t figure out what might be the problem. Any ideas?
(Régis Hanol) #6
Have you tried converting it to a PNG file?
(Anton) #7
Hm, no, should it matter? It has always been an .ico file and worked like that. If it’s expected to work and it does not, then I suppose it is a (minor) bug.
Converting to PNG would be a workaround, whereas I’m reporting to get it fixed. Hope it makes sense for you.
(Mittineague) #8
According to the Admin -< Settings -> Reguired input copy, maybe
favicon url
A favicon for your site, see Favicon - Wikipedia, to work correctly over a CDN it must be a png
(Anton) #9
It is not over a CDN in my case.
Btw, I use ICO because it contains multiple sizes. Is it a bad idea?
(Sam Saffron) #10
I think the issue is that the ico file is not publicly available because it is in a secure topic that only bypasses for png/jpg @zogstrip
(Jeff Atwood) #11
It’s kind of pointless today, and the ico file is a Microsoft proprietary standard. Just use a larger png file, and the browser will size it as need be.
(Anton) #12
Hm, in the ICO format there are many sizes, each designed and optimized individually by a graphics designer - e.g. tiny details removed as you size down. Automatic resizing of our icon does not work well (tried that first).
(Anton) #13
So, taking into account that ICO is supported by all browsers, and that there is a real use-case (described above) where ICO makes sense for not letting browser resize icon automatically, will you be able to make ICO from secure topics available as well? In other words, if you make PNG available from secure topics, why not ICO?
(Régis Hanol) #14
Ok, here’s how to fix your favicon issue
  1. Update your instance to at least this commit.
  2. Make a backup locally of your favicon if you haven’t already
  3. Destroy the upload related to your favicon via the rails console (Upload.find(<id>).destroy)
  4. Re-upload your favicon and use its url as your favicon url.
  5. :sparkler:
(Jeff Atwood) #15
