First list item number floating into SPACE
(Michael Brown) #1
  1. Go to the pfSense download mirror page
  2. Select a nearby mirror and download the latest appropriate image. For this hardware and a 4GiB CF card, it will be: pfSense-<VERSION>-RELEASE-4g-i386-nanobsd.img.gz
  3. Write the image to the CF card with the command:
     zcat pfSense-<VERSION>-RELEASE-4g-i386-nanobsd.img.gz | sudo dd of=/dev/path/to/cfcard bs=64K
^^^ the above renders fine on desktop, but on mobile the 1. is floating off to the right.
(Jeff Atwood) #2
I can confirm this still happens. @awesomerobot can you take a look?
(also has weirdness with posts that begin with oneboxes, quotes, etc so not limited to numbered lists.)
(Jeff Atwood) #3
@neil can you add this to your list, and note my caveats above.
(Jeff Atwood) #4
I think this is fixed? Can you verify next week @neil and also check posts that begin with oneboxes and quotes as well on mobile.
(Sam Saffron) #5
  1. is this fixed
  2. I am not sure
  3. lets see
cc @awesomerobot
(Jeff Atwood) #6
I believe @awesomerobot fixed this in a recent PR.
(Kris) #7
Yes, fixed here
https://github.com/discourse/discourse/pull/2129
(Jeff Atwood) #8
This topic was automatically closed after 24 hours. New replies are no longer allowed.
