Flag dialog doesn't work right on iPhone
(Lowell Heddings) #1
Whenever I try to use the Flag -> Spam -> Delete Spammer feature, it just doesn’t work (on the iPhone 5S using iOS7).
I also can’t make the dialog go away.
(Jeff Atwood) #2
Can you check this @neil?
(Neil Lalonde) #3
The modal buttons in this case are at the bottom of the iPhone viewport, which is not a usable part of the screen anymore, thanks to Safari iOS 7. This article discusses the problem in the “BOTTOM TOOLBARS AND INTERACTIVE ELEMENTS” section. Behaviour is very glitchy and broken when links and buttons are at the bottom.
I added a margin to the bottom of all modals on mobile so that it’s possible to scroll the buttons up into the interactive part of the screen.
(Jeff Atwood) #4
