Font size not consistent?
(Rob Jeffrey) #1
Hello all,
I am probably going mad, hopefully I can explain my problem.
When I set a text’s font size to say 14px, it appears to be a different size than the same font at 14px on another site.
Does discourse scale font? E.g if I set a font to 14px, is that just a ratio of another variable?
Specifically I have built a custom header in the theme customization settings and I am trying to match the header with my wordpress site for SSO.
Many thanks for reading this.
Rob
(Mittineague) #2
Only a wild guess. Does the WordPress site have a responsive design? i.e. the
<meta name="viewport"
 content="width=device-width,
 initial-scale=1,
 shrink-to-fit=no">
I’m guessing it’s the entire header being smaller and not only the font.
(Rob Jeffrey) #3
Thanks for the reply, my meta tag for wordpress is:
<meta name="viewport" content="width=device-width, initial-scale=1">
It appears the Wordpress fontsize is bigger than discourse at 14px.
Cheers
(Kris) #4
Hmm, we do scale fonts in various places across Discourse… but if you have a specific element set to 14px in your CSS it shouldn’t generally impact that.
Is your site public? If you can post a link I can take a look.
(Rob Jeffrey) #5
Many thanks for your reply Kris,
The discourse site is not public, but the WordPress side is.
http://socialrobotmarketing.com/wordpress-test/
The font in the header is set to 14px but on discourse the same font looks smaller:
Thanks for your help,
Rob
(Mittineague) #6
Out of curiosity, what are the computed line-height values?
(Stephen Chung) #7
There are multiple ways in CSS that a 14px font-size will turn out in display to diff from 14px.
You really need to open up developer tools and check the text elements of both the WP site and Discourse.
(Rob Jeffrey) #8
Checked values like line-height, font stretching and weight values.
It seems in Discourse 16px is the same as 14px in WordPress, I can live with this.
Line-height is 1.4 for both discourse and wordpress at the moment.
Thanks for your replies
