Forcing digest send for dev purposes
email
(Tom Bartlett) #1
I’ve been using rake enqueue_digest_emails and a user who hasn’t been seen for a while to test some digest email changes - is there a way to manually trigger the digest from within app? This is purely for dev testing, not to send to a live spam or similar.
(Arpit Jalan) #2
PROTIP: you can preview digest email from admin – http://discourse.example.com/admin/email/preview-digest
(Tom Bartlett) #3
Thanks @techAPJ , I’ve used that before, but the dev is to test deliverability of the digest emails, so I need to trigger actual sending of the emails. I am overriding the templates in a plugin (which is a bit of a faff to achieve - not like with the hbs templates which are a simple asset inclusion)
Currently, I’m doing this:
  1. Create a new topic (or 3)
  2. Run rake rake enqueue_digest_emails
  3. Give sidekiq a slap, hoping it will push them through
  4. Check /logs for any debug info
EDIT: This process does NOT appear to trigger a digest email.
(Erick Guan) #4
At the beginning of that rake task, it says desc "This task is called by the Heroku scheduler add-on". Apparently, it’s not for development.
Enter the rails console, Jobs::UserEmail.new.execute(user_id: -1, type: :digest) will give you something.
As of deliverability of the digest emails, what do you mean by that?
(Tom Bartlett) #5
Perfect - that line does exactly what I needed.
For clarity, this was my situation:
  • Trying to “brand” the email templates, by overriding them in a plugin
  • Had a bug which stopped digests being sent
  • Needed to trigger the digest manually to test the bug fix
“Deliverability” was probably a red-herring. I simply meant “I want to send the digest manually and see it in an inbox”.
