# Forum Index: forum topics aggregator app for iOS, macOS and Android
**URL:** <https://meta.discourse.org/t/forum-index-forum-topics-aggregator-app-for-ios-macos-and-android/417955>\
**Category:** Extras\
**Tags:** experimental\
**Created:** [20 november 2026 om 19:03 UTC](https://meta.discourse.org/t/forum-index-forum-topics-aggregator-app-for-ios-macos-and-android/417955 "2026-11-20T19:03:40Z")\
**Posts on this page:** 1\
**Page:** 1
## AI-generated summary
[pmusaraj](/t/-/417955/1) introduces **The Forum Index**, an experimental, personal side-project designed as a forum discovery and reader app for iOS, macOS, and Android. The app aggregates topics from thousands of independent communities, offering a "For You" feed, trending topics, and curated lists like "Quiet Corners" and "Hidden Gems." Currently, the app is not approved for the main App Stores but is available for testing via [TestFlight](https://testflight.apple.com/join/kvkNV4MD) and [Google Play](https://play.google.com/apps/testing/com.musaraj.forumindex).
The project consists of a backend application that crawls, classifies, and ranks topics, alongside open-source frontend apps. The iOS/macOS and Android repositories are public ([iOS/macOS](https://github.com/pmusaraj/forum-index-app), [Android](https://github.com/pmusaraj/forum-index-android)), but the backend remains private for now. Rendering utilizes Discourse's rich Markdown endpoints for compatible sites, falling back to HTML-to-Markdown generation for others.
Key features and limitations include:
*   **No Account Required:** Usage is anonymous, relying on a device ID to shape the "For You" feed. Consequently, user history is lost if the app is deleted.
*   **Read-Only:** The app is currently for discovery and reading only. Support for replies and reactions is planned but not yet available.
*   **Forum Submission:** Users can suggest new forums for inclusion via the app's settings.
*   **Platform Scope:** Currently limited to Discourse communities, though the implementation is not strictly Discourse-dependent, and expansion to other platforms is planned.
*   **Web App:** No web version exists yet, though pmusaraj is open to it if demand arises.
The project was built using AI coding agents, and the backend employs a decision model (available in Discourse core) and an LLM for topic classification and ranking.
<div class="post-metadata">
**Author:** ![pmusaraj](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/pmusaraj/32/119489_2.png) [@pmusaraj](https://meta.discourse.org/u/pmusaraj)\
**Post date:** [20 november 2026 om 19:03 UTC](https://meta.discourse.org/t/forum-index-forum-topics-aggregator-app-for-ios-macos-and-android/417955/1 "2026-11-20T19:03:40Z")
</div>
This is an experimental and personal side-project.
 ![CleanShot 2026-11-20 at 1.56.18 PM@2x](https://global.discourse-cdn.com/meta/original/4X/2/f/c/2fc4ac5707799d985cb05a4d38de343728031b1e.png)
> **[Forum Index — Find your next great community discussion](https://www.theforumindex.com)**
> The Forum Index is a forum discovery and reader app. It's a quick way to see what's new in thousands of independent communities.
The description there for end users is the following:
> **The Forum Index** is a forum discovery and reader app. It’s a quick way to see what’s new in thousands of independent communities. The app also helps you pick the subjects you like and fine-tune your own For You feed over time.
The current app is not yet approved in either App Store, but you can test it via [TestFlight](https://testflight.apple.com/join/kvkNV4MD) and [Google Play](https://play.google.com/apps/testing/com.musaraj.forumindex).
For seasoned meta users, some additional information in the form of an FAQ.
**How is this built?**
There is a backend application that crawls, classifies and ranks topics from the list of forums. That application also provides the feeds for each category, as well as a trending feed, a For You feed (for users that have minimal usage) and a few experimental lists called Quiet Corners and Hidden Gems.
**Is it open-source?**
At the moment, only partially. The iOS/macOS and Android app repos are open-source. The backend repo is not yet public.
[GitHub - pmusaraj/forum-index-app · GitHub](https://github.com/pmusaraj/forum-index-app) and [GitHub - pmusaraj/forum-index-android · GitHub](https://github.com/pmusaraj/forum-index-android)
**I would like my forum to be featured, how?**
Simple, run one of the apps and under the Settings screen (cog icon), enter the URL of the forum under Recommend a forum and submit it.
**Do I need an account?**
No. The app is meant to be a discovery and reading experience. No accounts are needed. What you read and bookmark helps shape a _For You_ feed which you can choose to use or not. We use a device ID as the identity of the feed in the backend, it is not associated with you as a user. (Downside is that you lose your history if you delete the app from the device.)
**is there a web app?**
Not at this time. I was curious about what was possible with native apps. If there is lots of demand and usage, I’m open to adding a web app.
**Is it only Discourse communities?**
At the moment yes, but I have plans to expand to other platforms. Nothing in the current implementation requires Discourse.
**Can I participate in the communities?**
At this time, no. I have a half-plan to add support for replies and possibly basic reactions (likes) in the near future. I do not plan to add any additional features though, the goal for this application is to be as minimal as possible.
**How does rendering work?**
The app uses [rich Markdown endpoints](https://meta.discourse.org/t/discourse-core-now-includes-markdown-endpoints-for-topic-lists-and-views/413006) for the Discourse sites that have that feature enabled (about 75% of the current index). For the rest, the backend app generates markdown from the HTML output.
**How is AI used?**
I built all the pieces of the project with a coding agent (various, actually). The backend also uses a decision model (now available in core) as a first pass for each topic and an LLM as a fallback. That’s for classifying and ranking the topics.
