Forum shows "Try Again" message
(Ankur) #1
Homepage of my forum opens correctly but when I click topic it shows “Try Again” message as in image. Please help to resolve it.
(Jay Pfaffman) #2
Has it ever worked? Have you tried rebooting?
If you start a new incognito session do you get the same error?
(Ankur) #3
Yes, it was working.
#4
@ankur1857, please tell us more info about the forum.
Can you pass the URL?
What version are you running?
What did you do that this message shows up now?
(Dje4321) #5
Is there anything in the logs?
(Ankur) #6
URL is ask.pharmaguideline.com
Version is latest
I had reconfigured the app.yml because last was deleted by mistake.
Is there something, I am missing?
(Ankur) #7
Error Log is showing
(Ankur) #8
Following is my app.yml
Everything is ok notification emails are being sent perfectly.
Problem is that it opens for a small time of period and then shows “Try again” message.
After some time (about 10 min) it opens correctly.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  # UNICORN_WORKERS: 3
  DISCOURSE_HOSTNAME: 'forum.mysite.com'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'me@mysite.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org         # required
  DISCOURSE_SMTP_PORT: 587                        # (optional, default 587)
  DISCOURSE_SMTP_USER_NAME: postmaster@forum.mysite.com      # required
  DISCOURSE_SMTP_PASSWORD: my-mailgun-password               # required, WARNING the char '#' in pw can cause problems!
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@mysite.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
          - git clone https://github.com/angusmcleod/discourse-quick-messages.git
          - git clone https://github.com/discoursehosting/discourse-adsense.git
          - git clone https://github.com/Ebsy/discourse-nationalflags.git
          - git clone https://github.com/discourse/discourse-topic-group-button.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-cakeday.git
          - git clone https://github.com/discourse/discourse-push-notifications.git
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-plugin-linkedin-auth.git
          - git clone https://github.com/vinkashq/discourse-content_lockers.git
          - git clone https://github.com/discourse/discourse-adplugin.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
run:
  #- exec: rails r "SiteSetting.notification_email='me@mysite.com'"
#9
Have been experiencing the same problem for the past 2 months as well. Keep getting the “429 Too Many Requests” message and the following error messages:
I have tried raising the rate limit via the ngx_http_limit_req_module and doubling my server’s storage, CPU, and RAM-- both to no avail. I am not sure if it is a server or software problem? Would appreciate the help!
My web address is forum.leasehackr.com.
(Ankur) #10
Some times it shows
#11
What pluggins do you have?
:cry:
I think you must restart with a backup.
(Ankur) #12
How to restore backup?
#13
:top: Reading first!
