Front page 404 non logged users
(Merqurio) #1
Hi everyone !!
I just created an instance with docker on basquewaves.com but when a non logged user enters to the forum, the front-page doesn’t render properly and in stead a 404, you can try it yourself the web is live
Thanks in advance for your help !
UPDATE:
I just updated the docker container but the error persists open_mouth
(Merqurio) #2
No clues ? Maybe a new installation ?
(Jeff Atwood) #3
How did you install, and where? Did you follow our official docker install guide?
(Merqurio) #4
It’s a docker installation in a digitalocean droplet and yes, I followed the official install twice, step by step. I erased the droplet, made a new installation from 0 but when I import the backup same error appears again. I’m trying to clear all the settings one by one, just to see if I did something wrong.
Really strange thing
It’s up and running, do you see same I do ?
Thanks !
(Merqurio) #5
Found, when I restored the suppress uncategorized badge option, everything started working well. But if I check it again the error doesn’t reproduce .
If you want the backup to check the error… I have no idea what could be the reason.
Thanks!
(Jeff Atwood) #6
I wonder if it is a localization bug. What language is Discourse set to?
(Merqurio) #7
It could be, I set spanish as lang. But the bug was there even if I set english as main language.
Thanks for the support ! :smile:
(Jeff Atwood) #8
So you cannot reproduce the problem? Maybe update to latest code via /admin/docker or /admin/upgrade.
(Merqurio) #9
I tryed to reproduce the problem and the only way was with a fresh install and importing the backup. Whatever is the language when, the bug desappears when I switch off suppress uncategorized badge option in the settings.
If I can do anything to help , please let me know
