Get absolute base URL
(Simon Cossar) #1
I’m trying to get uploaded audio files to return their absolute URLs. I’m doing this by overwriting the Discourse.Utilities.getUploadMarkdown function, in a plugin. It works, but I’m having to hardcode my site’s base URL into the function and then append it to upload.url. Is there a site setting for this that is available on the client side?
I am currently doing it like this, but there must be a better way.
// javascripts/lib/utilities.js
if (Discourse.Utilities.isAudioFile(upload.original_filename)) {
      return  'http://' + Discourse.BaseUrl + upload.url;
    } else {
 isAudioFile: function(path) {
    return (/\.(mp3|wav|ogg)$/i).test(path);
(Jeff Atwood) #2
I think @zogstrip would be the best person to answer this.
(Simon Cossar) #3
It turn out you can always get the absolute url from window.location.
(Régis Hanol) #4
window.location is nice but only works on the client-side. If you want it to work on the server-side too, Discourse.BaseUrl is what you’re looking for.
(Simon Cossar) #5
Yeah, except it doesn’t return the protocol part of the URL.
(Régis Hanol) #6
You can use the Discourse.use_https site setting to know that :wink:
