Get infromation from data explorer and put on user card
(Pad Pors) #1
is it possible to get some data from the data explorer plugin and then show it on user card?
basically we’d like to put some simple game in the forum, and show users progress to them as well as others.
is a plugin needed for this?
(Rafael dos Santos Silva) #2
Yes, with a plugin you can update a user custom field, and add it to user card.
(Leo McArdle) #3
You’re gonna need some ruby to do the actual database query, but in terms of the html/js side of things, my implementation of custom user cards on Namati’s Discourse instance may be of help to you:
Change data in user card by plugin
Important changes to Plugin Outlets for Ember 2.10
(SMHassanAlavi) #4
Can you explain your code?
I didn’t understand your html and javascript
